Difference in feature count of Neighborhood Finder transformer after upgrading from FME 2020 to 2024
  • March 13, 2025
  • 25 views
pragathjobs
Participant
Forum|alt.badge.img+3
Difference in feature count of Neighborhood Finder transformer after upgrading from FME 2020 to 2024. The count differs even though the input data and projection are same. Similarly for lineonlineoverlay transformer the tolerance 0 and automatic gives the same output while the expected was different as FME 2024 does not have an option to give “none” in tolerance.
j.botterill
Forum|alt.badge.img+34
Perhaps in the 2024 FME, before upgrading the transformer…..you can go to “Upgradable Transformers” and find this NeighbourhoodFinder transformer. Right click and find the ‘changes’. This graphic, post here, it might suggest why the newer version has newer parameters that handle/filter the features differently
