DGNStyler / DGN Writer not recognizing cell '1'
  • March 5, 2025
  • 18 views
rlacey
I have encountered a strange issue where FME doesn’t recognise a cell named ‘1’ in any of the cell files I have tried using it with.
This arises both using the DGNStyler, where the cell is missing from the pick-list (and it’s the only one missing),
and also by applying the idgs_cell_name format attribute, where the dgn writer gives the warning that the cell could not be found in the cell file and it will be dropped from the output.
This issue is in the 2022.2.4 FME Workbench currently our workplace standard, but NOT in an older 2017.1 installation.
Any suggestions would be appreciated.
AliAtSafe
Forum|alt.badge.img+19
  • March 6, 2025
Hi, ​@rlacey.
Thanks for posting to the community! Are you able to share sample data that includes the cell named ‘1’ and a log file? I can take a look from there.
Thanks!
