Cut 3D dgn/dxf lines by using 3d surface (pointcloud las, laz, dtm etc.,)
chaitanyamalla
I have dgn/dxf formatted CAD 3D lines which are "cables" below the ground. These cables are sometimes 1m below ground and sometimes 50cm and 10cm etc. below the ground. I have pointcloud LAS data as ground elevation data.
Now I want to extract the cables(lines) which are below the ground upto 50cm. I want to cut the cables layer with elevation model to selct the cables network from 0 to 50 cm below the ground.
How can I cut those lines? I am trying with qgis and FME but, unable to get the right solution. Anyone has idea what software or methods to follow.
AliAtSafe
Forum|alt.badge.img+22
  • June 26, 2024
Hi, @chaitanyamalla.
Thanks for your question. I’ll be happy to guide/assist you.
Before testing your scenario out, if you can, could you provide your datasets or a workspace template? It’ll help to see if there's a way to approach this. If not, not to worry, I can try to gather some resources/recreate your scenario.
All the best! 🙂
chaitanyamalla
HI @AliAtSafe, Unfortunately, i am not allowed to share the data, due to sensitive information. CAD cable dats is small, but Pointcloud LAS is very big data.
I was able to solve it partially by using QGIS & FME, but not fully.
DXF can be opened into QGIS directly or by converting into QGIS Geopackage (import export dxf) tool. I have taken points on cable network every 1m interval, and extracted Z values of cables onto points. I have converted LAS to RASTER DEM  .tif format so that every pixel has elevation value. Now I extracted pixel value to overlying Cable points.
Now our points data has both Z values(from cable and from elevation pixel values), just creating new attribute with difference of Z values. can give me points which are 0-50cm by filtering them. I can now tell approximately, the length of cable below ground tll 50cm by multiplying points with 1m.
daveatsafe
Forum|alt.badge.img+19
  • July 2, 2024
Hi @chaitanyamalla,
Please send the point cloud data to a TINGenerator transformer to created a TIN surface, then use an Extruder to extrude the TIN surface by -50 cm. Next add a Clipper, with the extruded TIN as the Clipper and the DXF cable lines as the Clippees. The Clipped output should be all the cable segments that are between 0 and -50 cm below the ground.
