CSV parameters reader
simeon.simic
I have network based resource folder, that folder si on fme flow
When file arrive in that folder, i need to write that file on other location, i just need help i don t know what parameter or what pointer should i send to my reader that it knows which file should write
j.botterill
Forum|alt.badge.img+34
  • March 14, 2025
I would suggest using Form with creator and feature reader > Directory and File Path reader format
In the parameters of the reader, there is even a path filter to ensure only *.csv are read in. Then there will be output attributes like file_name and windows_path. Use the windows_path on the writer
Then in Flow you set up an automation with File * Directory watcher, then a run workspace, pointing it to the above Form workspace
https://support.safe.com/hc/en-us/articles/25407764152973-Run-a-Workspace-When-Data-Arrives-in-a-Directory
simeon.simic
  • March 14, 2025
I will try this and give back to you my results, thank you !
