Convert Geodatabase to citygml
  • Nov 15, 2018 7:05 AM UTC
  • 106 views
kumarkannan1980
Participant
Dear All,
I need to convert basemap data (vegetation,roads,building) available in geodatabase format to citygml format.
Kindly advice
Regards,
K.Jayakumar
Forum|alt.badge.img+63
That is a very broad question, in short you'll have to look at the CityGML data model and compare it to what you have in your source data. Consider both the feature types (layers or tables if you will) and the attributes.
This video should give you an idea, but it is 5 years old and FME has evolved a lot in that time.
