Casesensitivity - Writer
  • May 26, 2015 11:31 AM UTC
  • 10 replies
  • 84 views
Hello,
Is there a possibility to disable the casesensitivity on the writer site? I am working with an AIXM Writer, with Attributenames in CamelCase (like validTime).
I get all Attributes in a CSV File in UPPERCASE (like VALIDTIME), and my Writer can't assign them because of that. Is there a Parameter I don't know of, to make that possible?
(I am working with FME Desktop 2015)
Thanks,
Melanie
pratap
Forum|alt.badge.img+12
  • May 26, 2015 1:25 PM UTC
Instead of the changing on wirter end, It is better to change before and send to writer.
Please review the transformer "StringCaseChanger", it will change the values based on the setting you have placed in "Case Change".
Hope this will help.
Pratap
  • May 26, 2015 1:30 PM UTC
Hi
have a look at the BulkAttributeRenamer, it can change all your attribute names to either upper or lower case for you.
David
  • May 26, 2015 1:53 PM UTC
Thanks, but changing it to uppercase will not make any difference, because its already uppercase. The Writer requires CamelCase, to make the right connections.
For example: Reader - VALIDTIME, Writer - validTime
The reader is dynamic, and I don't know its attributenames in the beginning. So I need the writer to recognize them in every case.
Melanie
pratap
  • May 26, 2015 2:01 PM UTC
Melanie,
Does this mean all the values will have upper case of next word?
To understand better, kindly provide 2 more examples?
Value1:
Input: VALIDTIME
Output: validTime
Value2:
Value3:
Pratap
gio
Forum|alt.badge.img+15
  • May 26, 2015 2:10 PM UTC
Maybe don't autogeneratte your workspace. do it manual, then  use casechanger and connect to your writer?
Did you also try selecting the connecting line to your writer, left click and choos auto-connect?
  • May 26, 2015 2:32 PM UTC
@Pratap
Attributenames in my CSV Reader are always uppercase. I need CamelCase on writer site (see http://en.wikipedia.org/wiki/CamelCase)
Value2:
Input: TYPE
Output: type
Value3:
Input: MARKINGICAOSTANDARD
Output: markingICAOStandard
@Gio
This wouldn't work. I get one CSV File that includes all Features. Attributenames differ per feature, those will be created at runtime.
It's a little complicated, i guess the only thing that will help is to change the input attributenames. :(
pratap
  • May 26, 2015 2:43 PM UTC
If it is possible for you to break the words?
MARKINGICAOSTANDARD = MARKING ICAO STANDARD
  • May 26, 2015 2:48 PM UTC
I have no influence on the CSV file, and at runtime i think it's not possible/easy to break the words in FME.
  • May 26, 2015 4:43 PM UTC
Sounds like a job for the SchemaMapper.
You could define the source and target attribute names in e.g. an Excel spreadsheet, then let the SchemaMapper rename the features at runtime.
Tutorial: https://knowledge.safe.com/articles/Samples_and_Demos/Mapping-Schemas-using-SchemaMapper
David
pratap
  • May 27, 2015 5:58 AM UTC
How many Distinct attribute values do you have?
