AutoCad Text Justification
  • December 4, 2012
  • 5 replies
  • 103 views
tbs_gis_team
I want to set my text justification to center. It has the option in the dwg styler for middle center but my text is not aligned to the center of my polygon I am labeling. I tried to set justification attribute to center but it will not work and FME bombs out.
Thanks,
Chad
fmelizard
Forum|alt.badge.img+18
  • December 5, 2012
Are you using a dwg template file? if you are the layer properties in the template file overwrite the workspace settings.
Hope this helps.
tbs_gis_team
  • December 5, 2012
I am using a template file, but the layer would not set my justification. I do have it set to swiss style font in my template set via the dwg styler. AutoCad has a center justification, but in the styler it doesn't. I have it set t middle center but it does not make the text center aligned in the dwg. I tried to make an attribute in FME for autocad_justification and made it center, but FME bombs when I do this.
Chad
tbs_gis_team
  • December 5, 2012
Got it, made the justification attribute, autocad_baseline_center and enable autocad_justification format attribute.
Chad
tim_bkr
Participant
Forum|alt.badge.img+5
  • Participant
  • November 17, 2014
Hello,
Does this also work for a justification within a block ?
I have tried it and the objects actually have the correct justification attribute. However, the text does not display justified. If I open the Attribute editor and Text options, under justification, the value is correct although the display isn't. If I reselect the same justification again, then the justification is good.
How can I solve this problem ?
Best regards,
Tim
  • May 20, 2015
Hello
I have the some problem
Have you solve thise problem ?
Thanks, Jacques
