ArcGIS Online Feature Service Reader Error Code '400' Deatils '24214'
sigbono
Forum|alt.badge.img+10
We published a feature layer in ArcGIS Online and when we try to read the features in FME Form 2024.1 (20240628 - Build 24612 - WIN64), we get this error.
ArcGIS Online Feature Service Reader: Encountered an unexpected error. The error code from the server was '400' and the message was: 'Cannot perform query. Invalid query parameters.'. Details: '24214: Circular arc segments with Z values must have equal Z value for all 3 points., Unable to perform query. Please check your parameters.'
Python Exception <ArcGISServerError>: FMEException: 928221: ArcGIS Online Feature Service Reader: Encountered an unexpected error. The error code from the server was '400' and the message was: 'Cannot perform query. Invalid query parameters.'. Details: '24214: Circular arc segments with Z values must have equal Z value for all 3 points., Unable to perform query. Please check your parameters.'
We have published two more feature layers and it all works fine. Does this have something to do with our data itself? Many thanks!
psl
Participant
  • Participant
  • July 24, 2024
We’ve been seeing errors across the board on FME Form - Workbench 2023.1.0.0 (20230825 - Build 23619 - WIN64) and FME Server for queries to Feature Services on ArcGIS Online. The error shown is more generic than what you shared:
ArcGIS Online Feature Service Reader: Encountered an unexpected error. The error code from the server was '400' and the message was: 'Cannot perform query. Invalid query parameters.'. Details: 'Unable to perform query. Please check your parameters.'
Error has been inconsistent yet frequent. In some cases multiple attempts to query will overcome the error.
spatialexjames
I am also regularly seeing the same error as psl “The error code from the server was '400' and the message was: 'Cannot perform query. Invalid query parameters.'.”, and also find retries sometimes work. For my case it’s attempting to write to a huge hosted table layer (no geometry) so I believe the size of the layer has something to do with it (>4 million features).
I am also finding that “sum” statistics (not “count” statistics) in ArcGIS dashboard widgets are failing for this layer and I get a “Cannot access data” error. This only happens once I try to apply any updates to the original features created in the layer so I know that issue isn’t related to table size alone. I haven’t got to the bottom of it but it feels like something underlying is breaking in the hosted layer, and I only get the “Cannot perform query” error once I start seeing the error in dashboard widget statistics.
One thing that may help is adding a “Field Index” for the attributes you are querying in the layer - might be worth a try.
I’m not sure about the circular arc segments error but that does sound like you’d need to inspect the geometry more closely - try changing the features per request on your writer to 1 and see which feature it’s failing on.
