Hello,
i'm pretty sure it's a simple problem, but somehow i'm not able to write a 3D shapefile. Every time I look at the feature information in the Data Inspector, I get "2D" as the dimension. But I need "3D" as dimension.
As a test, I have written the script below. After I have created a "test point", I create an attribute with a height, which I write into the Z-value using the 3DForcer. When exporting I want to write a 3D shapefile, but I have some kind of error and I can't see the forest in front of the trees anymore.
Thanks a lot for the help
