Using FileCopy Writer to copy single file to multiple subfolders
I have managed to use The Directory and File Pathnames reader, Attribute Manager and File Copy Writer to copy a file from one location to another.
How would I be able to copy that same file into multiple subfolders of a single parent folder?
I used this method so far.
kailinatsafe
Forum|alt.badge.img+21
Hello @nickj​, thanks for posting. Would you mind taking a look at the attached workspace? Here, we use a PATH reader to read the file being copied into each subdirectory (could also use a Creator/AttributeCreator to do the same thing)! A second PATH reader is used to grab a list of subdirectories you'd like to copy the file too. Using an AttributeCreator, we grab the subdirectory names and create a new attribute called 'destination_directory'. A FeatureJoiner is used to create 1 feature per subdirectory, and then a FileCopy Writer in fanout mode (fanout = destination_directory) can deliver the files to each subfolder. Let me know if you have any questions about the process! Happy to help, Kailin.
sveouu
Forum|alt.badge.img+3
  • April 16, 2025
Dear Kailin, Would you mind sharing the workspace again.
I think I have solved the issue I am having given your description of the workspace but would like to double check the logic :) thank you,
Svea
