Read two workbooks, identify common worksheets and then update from one sheet to another
  • Mar 29, 2024 9:39 PM UTC
  • 66 views
stevegrahambart
Observer
I am very new to FME and thought this would be a good exercise to get my feet wet.
However, I am having trouble locating help based on workbooks updates.
I have two workbooks named A and B for the example.
They both common worksheet names.
I want to read both workbooks, identify the common worksheet and update from a specific location from worksheet A to a specific location in worksheet B.
Cheers
Steve
ali-safe
Forum|alt.badge.img+24
  • Apr 1, 2024 6:14 PM UTC
Hi, @stevegrahambart, welcome!
Just wanted to clarify some things from your question.
For your worksheets, your trying to append/join data? If so, check out this article on joining/appending; has an example there too.
If not, are you trying to update the drive location of workbook A to the other drive location of workbook B after appending/joining (as above in the first question)? If so, you can click on the writer feature type itself and select the icon (image below).
Thanks!
