issue performing this (FME Flow Connection dialog opens, and he fills it out to connect to FME Flow running on his own machine:)
  • September 18, 2024
  • 7 replies
  • 39 views
evoteck
Forum|alt.badge.img+13
I am finding it difficult completing the task’s above on the image. how can I check my own username and password set during installation . Get the connection details from your FME Flow Administrator. If you are using FME Flow on your own machine, use http://localhost and your own username and password set during installation.
TandraAtSafe
Forum|alt.badge.img+7
Hi @evoteck, the username and password you’ll need to use for the web connection is created when you first log into your FME Flow on localhost. The first time you sign in, the default password for the username admin is set to “admin”.
You’ll be prompted to change your password after the first log in, and then for your web connection in Form you can use username “admin” and the new password you created. Please let me know if you need any more help getting your FME Flow web connection working!
evoteck
  • September 19, 2024
Hi @TandraAtSafe Yes I still need more help, because I can not remember the exact password I used, you can send me any meeting link on my mail @ (ezemaanthonysunday@gmail.com) so that we can have a live meeting session. through google meet or zoom. thanks
evoteck
I am checking the instruction here yet, it’s not clearer to me (https://docs.safe.com/fme/html/FME-Flow/WebUI/accessing_web_interface.htm)
TandraAtSafe
Have you followed the steps from Verifying the installation ? We have some other troubleshooting steps in our article Troubleshooting: Web Interface Login if there are still issues.
If you have forgotten your password but have logged into the web interface previously, are you able to reset your password via the web UI?
evoteck
@TandraAtSafe I downloaded FME flow , do I need to install it to my machine before I can get my login details because I only how FME form installed, could that be a problem. can we have a live video session so that I can share my screen.
TandraAtSafe
@evoteck I’d be happy to set up a meeting with myself or another support team member, but it would be best if you could submit a support ticket so we are able to track the details of this better.
evoteck
  • September 20, 2024
alright
