Hi, I am new using FME for cartography and I am not sure how can I create those elements in a raster map (north, graticule of coordinates, scale bar), I am currently using Mapnik rasterizer transformer to represent my raster and vector layers, and some labels, but I can't see how can I go from that to a complete map with all its elements. Thanks in advance!
How to create a graticule, north arrow and scale bar in a cartographic representation
Best answer by chrisatsafe
There are some transformers available that can help you with this but might not be as refined as the tools gazza mentioned. For example, one user has uploaded the ScaleBar transformer on the FME Hub. Personally I haven't used it myself so I'm not very familiar with it but you might be able to make use of that.
With regards to graticule lines, perhaps you could use a 2DGridAccumulator and a pair of LineBuilders (group by set to row in one, column in the other)? You could also extract the coordinates and create labels for the axis of your choosing. In the attached workspace, I have it placing labels on the bottom and right axis. From there, you could offset the labels, etc., etc.
Haven't tried the north arrow but hopefully that gives you a couple of ideas!
