How can I compress the output of Automation Action as zip file?
  • Mar 21, 2022 1:26 PM UTC
  • 103 views
mustafa.salah
Hello
I have an automation action that generates some files inside the FME Server 2021 Data folder, I need to zip the output folder after the action is complete. Can some one please advise?
e.g. after the action is complete, all results will be populated in
$(FME_SHAREDRESOURCE_DATA)/ALIM3263/destination/Extraction/
I want to compress whatever files in the extraction folder as one single zip file and save it to:
$(FME_SHAREDRESOURCE_DATA)/ALIM3263/destination/Compression/
Hi @mustafa.salah​ ,
I think you could approach this in two different ways:
  1. Zip the output within the workspace. E.g. Swap out the writer(s) for Feature Writers, followed by a FeatureHolder to wait until all files have been written and then zip the output e.g. using the ZipArchiver
  2. Create a second workspace that performs the zip process, and add it to the successful port of this workspace.
