FME Flow Automations Parameter in a Group Box
  • Sep 27, 2024 9:03 AM UTC
  • 74 views
bjoern
In FME Flow (2024.1.1.1) Automations, I cannot set parameter values ​​from a trigger to a workspace when the published parameters are in a group box. There is simply no select button. On the other hand, if I bring the parameter to the first level, it works. Is this a know issue or intentional?
luke.hicks
Forum|alt.badge.img+11
  • Sep 30, 2024 7:46 PM UTC
Hi @bjoern ,
I am sorry you are running in to this problem. I have done some testing myself and I can confirm that this seems to be a bug. For now if you are looking to use trigger values in your parameters, you will have to avoid using group parameter boxes.
If you would like to receive automatics updates on the progress of the bug fix, please contact our Customer Support and reference my name, and I will link you to the bug ticket.
Cheers,
  • Luke
