Why I can't change the transformer name for the FMEServerTransformers?
wicki
Forum|alt.badge.img+7
For all transformers it is possible to change the 'Transformer Name'. Why is not it possible for the FMEServerTransformers (at least in the version FME2016)? Is there a specific reason here?
I'm using the FMEServerJobSubmitter in my workspace very often, so i would like to be able to customize the name accordingly.
Forum|alt.badge.img+48
In FME 2017 and up you can easily change the name. Looking at the FMEServerJobSubmitter in FME 2016 that's being set up through a wizard. However, if you right-click it, or select it and hit F2, you'll still have the option to rename it.
wicki
  • March 22, 2018
Thanks for this fast answer.
Great that in the newer versions it is possible to change the name in the properties of the transformers quickly.
  • March 22, 2018
As a side note, my personal preference is to leave the transformer names as-is, since it makes it easy to see what type of transformer it is. If I need to attach a comment, I use an annotation (Ctrl-K after selecting the transformer), e.g.:
But, of course, in the end it's a personal preference :-)
I totally agree with @david_r on this one.
