using the filecopy in a feature writer - what paramaters
  • February 28, 2024
  • 248 views
andrewj74
Forum|alt.badge.img+5
I am trying to copy files within a work flow using the feature writer transformer. i dont want to use the writer as i want to carry on processing down stream of this action.
in the filecopy writer i can set the destination folder as below. however i cant see out to populate the parameter's in the feature writer, or its not clear. Anyone else managed to get this working?
Thanks,
Andy
Best answer by andrewj74
Great thanks- i think i got confused as the the dataset field in the feature writer is actually just the destination folder. Thanks for the info.
nielsgerrits
Forum|alt.badge.img+53
You need to set the format attributes:
filecopy_source_dataset
filecopy_dest_filename
Also see the documentation.
andrewj74
  • March 4, 2024
