Shutdown Python Script to retrieve the variable initiated on startup and write its value in the log file.
  • May 19, 2020 10:57 AM UTC
  • 94 views
a_afiaax
Hello FME community,
The attached Workbench is based on @david_r  Workbench "Retrieve a value from the Python startup script".
I added a Shutdown Python Script to retrieve the initiated global variable in startup and write its value in the Log File.
I got the following error on Translation log:
PythonFactory failed to load python symbol `FeatureProcessor'
Factory proxy not initialized
I am using FME2018.1.1.1  WIN64 with 3.6 Python Compatibility.
Does anyone have any solution or other potential solutions to pass global variable from startup to Shutdown and write its value in the Log File?
Link for @david_r orginal Workbench:
https://knowledge.safe.com/questions/58082/passing-parameters-from-a-python-script-tool-to-a.html
Regards,
Afia
@mark2atsafe @egomm12 @david_r @jlutherthomas @arnold_bijlsma @jdh @majdoleen @redgeographics @danilo_fme
  • May 19, 2020 11:23 AM UTC
Try setting "GetMyValue" as the function name to process features:
More info in the documentation: https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Transformers/Transformers/pythoncaller.htm
a_afiaax
  • May 19, 2020 12:14 PM UTC
Thank you @david_r , it works well.
