Set unit settings too meter or Kilometer
  • Mar 23, 2016 11:54 AM UTC
  • 204 views
Hello, I hope someone can help me with this (i think simple) question. For my study I need to Data Interoperability extension in ArcGIS. The objective is to create a 5 kilometer or 5000 meters buffer around a cycle route in Europe. I must create this buffer with a spatial ETL tool in the FME workbench. In the workbench I cannot find where I can set the unit settings to meters or kilometers. Where can I set the unit settings to meter or Kilometer?
Thanks in advance.
  • Mar 23, 2016 12:01 PM UTC
Hi
The Bufferer works in ground units, i.e. the same units used for your coordinate system. If your data is in a coordinate system based on meters, a buffer of 5000 will correspond to a buffer size of 5 kilometers.
If your data is in degrees, you can use the GeographicBufferer to specify the buffer size in meters or kilometers.
David
