SDF in Data Download Service
  • May 17, 2017
  • 39 views
jneujens
Hi everyone,
I am having trouble with downloading SDF output as a data download service.
The workspace itself is really simple:
- 1 SDF reader, reading a file containing 10 features;
- 1 transformer;
- 1 SDF writer, creating a file containing 10 features.
When this process is executed from the FME Server environment as a job submitter service, there is no problem.
When the same is executed as a data download service, I can see in the log that 10 features are written. The download link also shows the output .sdf file, but it contains 0 features in data inspector (instead of 10).
When we write to e.g. shapefile as a download service, there is no problem.
So, to summarize, it appears to be impossible to use SDF files in a data download service?
I know it has worked before, so I am wondering if anyone had the same problem? Suggestions how to solve this?
Thanks in advance!
Best answer by rylanatsafe
Please note that the Autodesk MapGuide (Version 6.5 and older) SDF Reader/Writer has been deprecated. You might try using the Autodesk MapGuide Enterprise SDF (Version 3) Reader/Writer.
@jneujens - If you are still experiencing this issue, sharing a few more details will help the FME community help you. Please reply to this thread and provide additional details including:
  • The version of FME Server you are using, including build number and edition
  • Your FME workspace and sample data
  • Your FME Server translation log file from both Job Submitter and Data Download
  • Any other information that may be useful to share
And please let us know if you already have submitted a ticket with Safe Support.
rylanatsafe
Forum|alt.badge.img+13
  • July 28, 2017
