PythonCaller: No Geometry or original attributes are returned
lorenrouth
Forum|alt.badge.img+8
This script works, but leaves out the geometry and original attributes.  My hunch is there’s something wrong with the close(self) function, but I’m stumped.  The code takes a feature id number and list of nearby ids from a NeighborFinder list, where it matches them up and assigns a _group_id attribute to  use with the Aggregator.  Really, it should be part of NeighborFinder.  The way I had been grouping features is to use two or more AttributeCreators and assign a common Id from the feature and id list.  It’s a hassle because you end up with duplicate features.  Very inelegent.
I have seen a few posts on missing attributes, but I can’t see how they apply to my code:
import fme
import fmeobjects
from collections import defaultdict
class FeatureProcessor(object):
    def __init__(self):
        self.og_ids = []
        self.closest = []
        self.lines = []
    def input(self, feature: fmeobjects.FMEFeature):
        id_number = feature.getAttribute('_count_Glaz_H')
        if id_number is not None:
            self.og_ids.append(id_number)
        nearby_ids = feature.getAttribute('_closest{}._count_Glaz_H')
        if nearby_ids is not None:
            self.closest.append(nearby_ids)
    def create_lines_list(self):
        for id_number, nearby_ids in zip(self.og_ids, self.closest):
            if isinstance(nearby_ids, list):
                nearby_ids = ','.join(map(str, nearby_ids))
            line = {
                'Id Number': id_number,
                'Nearby Ids': [int(nearby_id) for nearby_id in nearby_ids.split(',') if nearby_id.strip().isdigit()]
            self.lines.append(line)
        return self.lines
    def assign_group_ids_to_lines(self, lines):
        adjacency_list = defaultdict(list)
        for line in lines:
            id_num = line['Id Number']
            nearby_ids = line['Nearby Ids']
            for nearby_id in nearby_ids:
                adjacency_list[id_num].append(nearby_id)
                adjacency_list[nearby_id].append(id_num)
        def dfs(node, visited, group_id):
            stack = [node]
            while stack:
                current = stack.pop()
                if current not in visited:
                    visited.add(current)
                    for line in self.lines:
                        if line['Id Number'] == current:
                            line['Group Id'] = group_id
                            break
                    for neighbor in adjacency_list[current]:
                        if neighbor not in visited:
                            stack.append(neighbor)
        visited = set()
        group_id = 1
            if id_num not in visited:
                dfs(id_num, visited, group_id)
                group_id += 1
        return self.lines
    def close(self):
        self.create_lines_list()
        lines_with_group_ids = self.assign_group_ids_to_lines(self.lines)
        for line in lines_with_group_ids:
            feature = fmeobjects.FMEFeature()
            feature.setAttribute('_group_id', line.get('Group Id', 0))
            self.pyoutput(feature)
    def process_group(self):
        pass
Any insight is appreciated.
Thanks,
-L
Best answer by lorenrouth
Hi @birgit ,
Ok, I figured it out.  I needed to make a list of the incoming features and then zip them with the new attribute.  It works!
import fme
import fmeobjects
    def __init__(self):
        self.og_ids = []
        self.closest = []
        self.lines = []
        self.features = []  # Store references to the original features
            self.features.append(feature)  # Store the feature reference
            line = {
        return self.lines
        for line in lines:
            stack = [node]
            while stack:
                            break
        visited = set()
        group_id = 1
                group_id += 1
        return self.lines
    def close(self):
        for line, feature in zip(lines_with_group_ids, self.features):
        pass
birgit
Forum|alt.badge.img+16
  • June 19, 2024
Maybe it has something to do with the fact that in your closing statement you create a new empty feature and output that feature to the output port? See below:
    def close(self):
            feature = fmeobjects.FMEFeature()   <---- OVER HERE!
And your original features are never sent to the output port and are missing. If you want the original geometry and attributes to your new features instead then you need to assign them to the new feature as well.
lorenrouth
Hi @birgit ,
import fme
import fmeobjects
    def __init__(self):
        self.og_ids = []
        self.closest = []
        self.lines = []
            line = {
        return self.lines
        for line in lines:
            stack = [node]
            while stack:
                            break
        visited = set()
        group_id = 1
                group_id += 1
        return self.lines
    def close(self):
        pass
