Parse JSON list problem
  • Feb 18, 2015 7:42 PM UTC
  • 45 views
I cant achieve to to parse correctly json elements and attributes correctly. The json received is like this:
 {   "elements": [ {   "type": "way",   "id": 98815885,   "nodes": [     3325506694,     3325506698,     3325506701,     3325506705,   ], }, {   "type": "way",   "id": 98815895,   "nodes": [     1142949510,     1142941660,     1142983536,   ] } ] }
I am using the JSONFlattener, then the AttributesExposer (with elements{}, elements{},nodes{}, elements{}.id and elements{}.type) and finally the listExploder on elements{}.
The number of parsed feature is correct but there is no data inside the nodes attributes of each features. It's like if elements{}.nodes was empty for each feature.
Best answer by jdh
I would use a JSONFragmenter
incidentally your posted json has trailing commas after the last value in an object or array
jdh
Forum|alt.badge.img+41
  • Feb 18, 2015 8:32 PM UTC
