Out of a huge number of Polygone couples finding the nearest cuple part along a line
knigge
Forum|alt.badge.img+4
Hello there,
I got 3 tables. There is one table with polygones (A) and two with lines (B and C).
The lines in table B are going through my polygones. With the LineOnAreaOverlayer I cut the polyonges (A) in two. Now I need to know which part of the cuttet polyone is further away from my lines out of table C (in a max distance around the lines in C from ± 10 meters).
For each cuttet polygone couple I need the furthes away one from the lines out of C.
So along my C Lines are a lot of cutted polygone pairs. For each pair I need just the polygone which is further away.
Any ideas?
I tried the NeighborFinder alrdy, but dont geht my result.
Thanks a lot!!!
Best answer by nielsgerrits
NeighborFinder, polygons are bases, lines are candidates, distance unlimited, number to find = 1.
You can then sort on _distance and use a Sampler, group by original polygon ID to find the closest one.
nielsgerrits
Forum|alt.badge.img+53
  • May 21, 2024
knigge
  • May 21, 2024
Hey nielsgerrits,
thank u very much for ur solution! It worked the way I need it :D.
Best regards
nielsgerrits
knigge wrote:
Hey nielsgerrits,
Best regards
Cheers!
