Is it possible to email from a Python Shutdown script on FME Server?
  • September 5, 2018
  • 7 replies
  • 49 views
tb09114
Forum|alt.badge.img+22
I was wondering if it is possible to access the content of a workbenchs log file in a Shutdown Python script on FME Server and email the content.
I have a central workbench calling several other workbenches to perform analysis. I want to parse the finished log-file to get warnings, errors and information about features identified and written. The final statement if the run was successful is unfortunately not enough.
The parsed data should be send as text in an email.
Until now I was testing locally with success, but the same workbench at a 2018 server fails with FME_END_PYTHON failure.
import fme
import smtplib
from email.mime.text import MIMEText
from email.mime.multipart import MIMEMultipart
from email.utils import COMMASPACE, formatdate
def send_email(send_from, send_to, subject, text, server='*****'):
'''send email with analysis results'''
assert isinstance(send_to, list)
outer = MIMEMultipart()
outer['From'] = send_from
outer['To'] = COMMASPACE.join(send_to)
outer['Date'] = formatdate(localtime=True)
outer['Subject'] = subject
outer.attach(MIMEText(text))
smtp = smtplib.SMTP(server)
smtp.sendmail(send_from, send_to, outer.as_string())
smtp.close()
m_text = fme.logFileName
send_email('*****', ['*****'], 'Log file from server', m_text)
erik_jan
Forum|alt.badge.img+17
  • September 5, 2018
Would it be an idea to use a Notification (email after successful run) instead of a shutdown script?
I have been using that a lot and it works fine and is easy to implement.
  • September 5, 2018
It should definitely be possible. But have you checked that all the necessary modules are available in the Python interpreter that's used on FME Server.
Also, can please you post the complete error message on FME Server.
  • September 5, 2018
An alternative is to "wrap up" the workspace in a master workspace that uses the FMEServerJobSubmitter followed by the FMEServerLogRetriever and an Email transformer.
jdh
Forum|alt.badge.img+28
  • September 5, 2018
I second using a notification email. You can customise it in the "central workbench".
tb09114
  • September 5, 2018
As far as I can see is there not much of an error message. I attach a screenshot of the result data section
tb09114
  • September 5, 2018
I do not have huge experience in using the notification email, but if its possible to get the parsed data into the notification email then I will do this.
tb09114
  • September 5, 2018
Interesting!
