HTML Extractor with parameters
  • August 2, 2023
  • 46 views
checcosisani
Forum|alt.badge.img+12
I'm trying to built a webscraper tool for italian website using CSS (NO API available) and since each website has a different structure I put the css selector in a POSTGRES table and then in the HTML extractor I use these selectors as parameters
imageThe probelm occurs when in a website an attribute is missing
eg normally I extract data_inizio and data_fine but in some case data_fine isn't present.
So I suspect that the html stop if th css for a specif parameters is missing, I tried to use the conditional value butthe only possibility is stop
So the question is how can tell to the HTML if the css selector in a parameter is missing proceed ?
Hope the explanation is clear
thx for support
Francesco
Forum|alt.badge.img+32
  • August 2, 2023
So the issue is the missing attribute value in the HTML Extractor causing the extract to fail and rejected features?
If you use a NullAttributeMapper to map empty, null and missing attributes to a dummy value that should never match anything, the HTML extractor will then just return a blank for that css selector
