How to group multi line (text file) into individual features?
I received a text file that has descriptions about features as follows:
ADD FUSE 9911 {
PHASES =1;
PORT_A = <123>;
PORT_B = <234>;
ATTRIBUTE[county] = "SEATTLE";
ATTRIBUTE[street] = "MAIN ST";
ATTRIBUTE[facility_id] = "1324";
ATTRIBUTE[feeder_id_1] = "FD1";
ATTRIBUTE[feeder_id_2] = "Null"; }
ADD 1p_conductor 125623 {
Now, how to create individual features out of these?
1. I tried Aggregator:
groupby - text_line_data
Separator character: };
2. Tried to loop text_line_data and break whenever "};" is encountered. But both didn't work.
Is there a simple way to do this?
Best answer by erik_jan
Read the text file into one attribute.
Use the AttributeSplitter and split on }; to create a list.
Use the ListExploder to generate objects per list item.
That will generate the different features.
Next you want to split each feature again on ; to get the different attributes in a list.
erik_jan
Forum|alt.badge.img+17
  • March 4, 2016
gio
Forum|alt.badge.img+15
  • March 7, 2016
@vindastra
That will ignore the first itemname..
Use a txtreader read by row.
Ue a variableretriever and searchers
The not matched will give (in order). the attributes and value rows.
Test for not empty rows and rows witt "neither ";" nor "}" (newlines/carriagereturns etc.) and then searchers again.
Then..well.. here is example..
mark2atsafe
Forum|alt.badge.img+43
Forum|alt.badge.img+5
What's the best transformation to make a value pair (attribute name=attribute value) stored in a list element _attribute(1) into a feature attribute name and attribute value. e.g. see screenshot. So a feature with _attribute(3) with value "iso=0" will have a new attribute named "iso" and a value of "0". 2016-03-31-07-21-57-fme-data-inspector.png
I tried the KeyValueAttributeCreator but it seems by Key,Value pair delimiter which is a LF or \\n is not being read.
  • March 31, 2016
Hi @geospatiallover, I think a quick way is to remove "<any string>=" from the values, then rename the list elements. e.g.
@takashi....thanks. I started with a renamer after my splitter and got lost with putting an expression on the output value. Thanks for your help once again. Strings have always been my weakness in FME.
Just a thought, what if the attribute name keeps changing? This is metadata for UAV collected JPEGs and once another camera is used then the attribute schema will change. Any suggestions @takashi? I sure hope Safe would have a JPEGExif writer soon. Not a lot of voters yet on this idea.
  • March 31, 2016
You can use the KeyValueAttributeCreator after you have concatenated the list elements with a specific delimiter string. e.g. using the ListConcatenator.
Thanks again!
