Group points using count rule
Hello, probably this is something easy to achieve but I'm still new to FME.
I'm reading a set of points from a DWG file. These are definition points from a dimension feature. Each dimension object has 3 definition points, but there is no dimension ID. All that I have is a set of points listed consecutively; the first 3 points belong to one feature, the next 3 points belong to another feature and so on. I want to group all points using a count or split rule but so far I can't find a way to implement it.
Here is an example of what I want to accomplish.
Count   fme_feature_type
1 	Dimension		|
2 	Dimension     		|--> Group 1
3	Dimension		|
4	Dimension		|
5	Dimension		|--> Group 2
6	Dimension		|
Thanks
Best answer by ebygomm
Use an attributecreator you can set the attribute value of a new attribute called group using ceil(@Value(count)/3)
gio
Forum|alt.badge.img+15
  • June 28, 2016
group = ceiling (count/3).
  • June 28, 2016
Thanks for the reply, but could you tell me what type of transformer should I use?
Forum|alt.badge.img+32
  • June 28, 2016
  • June 28, 2016
Nice solution, thanks much!
Forum|alt.badge.img+5
The other way would be to use a Counter and a ModuloCounter. Take the modulo count away from the full count (ExpressionEvaluator) and you get a unique ID for that group (the ID would be 3, 6, 9, 12, etc instead of 1, 2, 3, 4; but it will be unique for that group)
