FME Server published parameter file naming
  • May 7, 2019 5:46 AM UTC
  • 138 views
I have a workspace with a published parameter setup to receive a name from the user that is then appended to the file name in an Excel writer. It works just fine in FME desktop, but when the workspace is published on FME Server it doesn't.
In the writer destination file I have ./Filename_$(value).xlsx
If I set the value parameter to "apples" FME Desktop generates a file named Filename_apples.xlsx
FME Server creates a file named Filename_$(value).xlsx
Do I need to use escape characters or something to force FME Server to use my parameter?
FYI I'm using FME Server 2018.0 and publishing using the same version of FME Desktop.
Not a critical issue, but I'm curious why it's not working.
Thanks
nielsgerrits
Forum|alt.badge.img+67
This works for me in Server 2016. I use this often, but I usually don't write to Excel. But it works with dwg / gdb.
But all my paths are hardcoded UNC, not relative. And I think my dynamic filenames are set in attributes, based on parameters.
  • May 8, 2019 12:01 AM UTC
Thanks for the suggestion. I have tried the Fanout Dataset option within the writer using an attribute for the file name that is generated from the published parameter within the workspace. This appears to be the only way to use an attribute value as the file name within the Excel writer.
The good news is it works. It just creates the files within separate directories, which I can live with.
However, the way I had it setup originally really should just work in Server as it does with Desktop. If anyone knows why it doesn't I'd be interested in hearing about it.
nielsgerrits
Just tested this in 2016 and it works as it should:
Make sure there are no quotes around it.
Our server is on Windows. I tried both ./Filename_$(value).xlsx and .\\Filename_$(value).xlsx which made no difference. Maybe it does on your installation if it is not on Windows?
  • May 8, 2019 10:37 PM UTC
Thanks again for the assistance. In FME 2018 the Feature Writer Parameters for Excel look much different...
XLSX Writer options...
Unless there's another way to access and change the Feature Writer Parameters I just can't find the same options that you have shown. Perhaps at 2018 there were significant changes to the Excel writer? Potentially breaking the functionality we are testing.
I think I'll log a help request to get to the bottom of it... and report back with the findings.
