Dynamic writer not working in FME 2018
  • Mar 16, 2018 2:41 AM UTC
  • 6 replies
  • 120 views
I have a workspace with a dynamic writer writing to postGIS. The source for the writer is a csv spreadsheet which is loaded from a workspace resource using schema (from table). The reader reads a table named "test", and the writer outputs to a table named "Mapped". It is essentially based on this tutorial:
https://knowledge.safe.com/articles/1046/dynamic-workflow-tutorial-destination-schema-is-de-1.html
except that I don't use fme_feature_type as the writer table name.
This is my csv source file:
The columns all appear to be mapped correctly.
This is the writer:
This was working in FME 2017, but since I upgraded to 2018 it no longer works. I get an error message saying:
Cannot find a matching schema named 'Mapped' in the known set of schemas: ''. Known schema sources are: 'Schema from Schema Feature, SCHEMA_FROM_TABLE_1'. Please verify writer feature type configuration.
Then there's a message saying:
POSTGIS Writer: Fanout for feature type 'Mapped' failed to find feature type template 'Mapped'
I am puzzled as to why the "known set of schemas" list is showing up as empty.
I feel I must be making a silly mistake somewhere, but as I say, it was working until yesterday.
I would appreciate some help if possible.
Best answer by fmelizard
Hi @rohan and @takashi,
The issue has been resolved in 2018.0 builds 18287+ and 2018.1. 2018.0 build 18287 or higher and 2018.1 betas should be available next week through through https://www.safe.com/support/support-resources/fme-downloads/ and https://www.safe.com/support/support-resources/fme-downloads/beta/
  • Mar 16, 2018 3:58 AM UTC
Hi @rohan, I was able to reproduce the same issue as yours. It seems that the Schema (From Table) reader and/or the mechanism for deriving schema definition from a lookup table have been broken in FME 2018.0. It's a terrible bug if my observation was correct.
@daleatsafe, could you please check these demos?
fmelizard
Forum|alt.badge.img+22
  • Mar 16, 2018 5:52 AM UTC
Thanks for highlighting. We're on it.
fmelizard
  • Mar 16, 2018 9:07 PM UTC
Thanks for letting us know about this one @rohan & @takashi -- you managed to find a path through things that did get inadvertently harmed in FME 2018.0. The fix has already been made and will be made available in a hotfix shortly (and additional tests have been added to our suite so that this can't happen again).
We'll notify here when the new build is available.
fmelizard
  • Mar 21, 2018 5:30 PM UTC
  • Mar 21, 2018 11:10 PM UTC
Thanks to everyone for their help. I will download the new build when available.
  • Mar 22, 2018 1:18 AM UTC
Good to hear. Thanks for the fix.
