Dynamic attribute names from Excel
peteralstorp
New year - new problems.
I have an excel file with fieldnames Layer 1, Layer 1, Layer 2, Layer 2. My second and third row of data consists of defining parameters per column that I need to decide how to route the actual data. These parameters can vary from sheet to sheet, and I need to handle multiple sheets with the same routine.
And then I have my actual data values on row 4 and forth.
Example:
Stone, Stone, Clay, Clay
Time, Depth, Time, Depth
1, 0.5, 0.2, 0.3
0.4, 5, 0.2, 0.3
To be able to handle route the data correctly I need to create attribute names and then have these names apply to the actual data.
Any ideas on how to solve this?
Best answer by takashi
There may not be easy ways. The attached workspace example contains two workflows: one uses several transformers including AttributeExploder, Aggregator, FeatureMerger, and BulkAttributeRenamer; another uses just a single PythonCaller.
dynamic-attribute-names-from-excel.fmwt (FME 2016.1.3)
Hope this helps.
  • January 3, 2017
Lots of ways, but take a look at the SchemaMapper, it was made for this type of scenario.
It is a bit complicated to get the hang of, however, but there are several good tutorials.
peteralstorp
  • January 3, 2017
Thanks, David, I was afraid the SchemaMapper would come up! I tried it a few times but we're not the best of friends... I'm going to check out the tutorials (again!). Is there any one in particular that you feel might be a good start in this case?
  • January 3, 2017
I'll admit I'm not a huge fan of the SchemaMapper either ;-)
Some options:
  • Use Joiner(s)
  • Excel reader with FeatureMergers
  • Excel reader with InlineQuerier
I'm sure there are more...
Hi @peteralstorp
you can specify what row contains attribute names (is it row 3?) If necessary, you can read the same Excel spreadsheet more than once - e.g. to access first 2 rows that can later be used for some kind of decision making (how to route your data).
  • January 4, 2017
Hi @peteralstorp, can you explain the requirement in little more detail?
  • Do the first three rows always contain elements that should be used to determine the meaning of each column?
  • Is the number of columns always four?
  • What attribute names do you need to create based on the first three rows? For example, you need to create "Layer 1 Stone Time", "Layer 1 Stone Depth", "Layer 2 Clay Time", and "Layer 2 Clay Depth" as attribute names for each column?
etc...
peteralstorp
  • January 5, 2017
etc...
Of course, takashi!
Although I solved this the ugly way (since the sheet is looked I setup the concatenated column names before hand and made them unvisible). So, if you don't have the time there's no problem.
Yes, the first three elements always need to be needed. After the first three columns the data block follows with 1-n rows.
And yes, for instance "Layer 1 Stone Time", that's what I need.
Thanks for helping, either way.
Peter
  • January 5, 2017
Hope this helps.
  • January 5, 2017
peteralstorp wrote:
Of course, takashi!
Peter
Hope this helps.
peteralstorp
  • January 5, 2017
Hope this helps.
Nice, Takashi! I like the python solution. Wish I could do more with Python myself. I can't seem to mark your answer as Correct. Maybe you need to post it as a reply?
