Date string invalid format
  • December 16, 2022
  • 90 views
townest
Forum|alt.badge.img+4
Hello,
I have the following date string(s):
image.png...which I need to convert to datetime objects. They appear to be 'iso datetime with offset', however I continually get invalid format with auto detect or manual choosing format. I have tinkered with several other input formats to no avial.
imageAny ideas?
Thank you,
Tyler
FME Workbench 2022.1
Best answer by ebygomm
There is a bug with attribute selection in the DateTimeConverter
See here
https://community.safe.com/s/question/0D54Q00009tzKL5SAM/datetimeconverter-version-4-produces-invalidinput
As @thijsknapen​ says, if you correct this the transformer should run correctly
thijsknapen
Forum|alt.badge.img+10
  • December 16, 2022
I think your the input for your Datetime Attributes is at fault. Try changing from '@Value(date_in)' to 'date_in'.
The following seems to work for me;
Forum|alt.badge.img+32
  • December 16, 2022
See here
townest
  • December 16, 2022
Oy...I should have noticed that...too focused on the format string. Thx.
