Database Connection: Permission Error or Java Error?
notmyname
Participant
Hello,
When I try to connect to existing stored database connections or new database connections. I get the errors outlined below. The error sound like either a java or permission error.
Does any one have advice on how to figure this issue out?
Thanks!
Background Info
  • SQL server and SDE connections
  • Can connect to local (SQL Lite) database
  • I have previously connected to all the databases I currently can't access
  • I currently have permission to access the databases, tested with SQL server management studio
  • Issue appeared in the last week or so
  • Connecting with windows authentication (not server authentication)
  • Desktop bit FME(R) 2018.0.1.0 (20180518 - Build 18310 - WIN64)
Similar to these topics:
SQL Server and ArcSDE I get the error:
"Unable to Retrieve connection NameOfConnection Please check log file. The message window lists some Java error. Image below:
Accordingly I thought my old connection may have an issue, so I went to create a new connection to the same database, and receive the error below.
jovitaatsafe
Forum|alt.badge.img+11
Hi @notmyname,
Sorry to hear that you've run into this issue. Which MSSQL non-spatial reader are you using (JDBC or Azure)? And what version of MSSQL Server are you using? Would you also be able to share your full log file? I noticed that the provider error that you're getting is listed in this article. Even though the initial message is a bit different, would you able to give that a look through and see if any of those causes and resolutions apply to you?
Please let me know if any of those work for you, and if not, I can do my best to help you troubleshoot further.
notmyname
Participant
  • Participant
  • November 1, 2018
jovitaatsafe wrote:
Hi @notmyname,
Thanks for the response. It is SQL server 2014. I solved my problems by ignoring them and installing the latest version of FME.
notmyname
Participant
  • Participant
  • November 1, 2018
Solved by upgrading to latest FME version
