change format of table
  • February 27, 2018
  • 12 views
barrett_h
Hi all,
I have an attribute table in the following format:
localitycountmonthbright123janbright456febbright789marmyrtleford987janmyrtleford654febmyrtleford321mar
I would like to change it to the following format:
localityjanfebmarbright123456789myrtleford987654321
I have a convoluted process using an attribute filter and a bunch of statistics calculators but it's not very scaleable. I was wondering if anyone can point me in the right direction for an improved solution!
Cheers,
Barrett
Best answer by takashi
Hi @barrett_h, I think a general approach is to rename 'count' to the value of 'month' in the same record, and then aggregate the records grouped by 'locality'. An implementation example is:
Instead of renaming with the BulkAttributeRenamer, you can also use the AttributeCreator to create a new attribute whose name is equal to the value of 'month' and assign the value of 'count' to that. This may be easier to understand.
Here is another approach. Create a JSON document containing pairs of key (month) and value (count), and flatten it to extract the key/value pairs as attributes.
There is more than one way, but I usually use the BulkAttributeRenamer in a similar case.
Hope this helps.
Forum|alt.badge.img+22
  • February 28, 2018
Hope this helps.
  • February 28, 2018
Hope this helps.
If you were familiar with Python scripting, the PythonCaller could also be an alternative of course.
# PythonCaller Script Example
class FeatureProcessor(object):
    def __init__(self):
        # {key=locaity : value=feature}
        self.kv = {}
    def input(self, feature):
        loc = feature.getAttribute('locality')
        mon = feature.getAttribute('month')
        cnt = feature.getAttribute('count')
        self.kv.setdefault(loc, feature).setAttribute(mon, cnt)
    def close(self):
        for feature in self.kv.values():
            self.pyoutput(feature)
barrett_h
  • February 28, 2018
Hope this helps.
Those are great suggestions @takashi! Thank you very much, I ended up going for the JSON idea as it provides so much flexibility.
