can one use a template file in feature writer with excel as output format?
felipeverdu
Forum|alt.badge.img+10
Hi
my question is if one can use a template file in feature writer with excel as output format
/F
  • March 12, 2020
Depends on the format you're writing to. If a template file is supported in the "regular" writer of that particular format, then it should be supported in the FeatureWriter as well.
felipeverdu
  • March 12, 2020
Hi @david_r,
It is to Excel...and I can't see there is an option.
fgiron
Forum|alt.badge.img+20
  • March 12, 2020
felipeverdu wrote:
Hi @david_r,
You have to set Overwrite Existing File to Yes
Forum|alt.badge.img+32
  • March 12, 2020
You will see the option if you change Overwrite Existing File to Yes
felipeverdu
  • March 12, 2020
Hi
it did ...
Thx! @ebygomm
Felipe
