Bug in FME ? - "SQL to run after write" triggered even after a Terminator is activated
  • Oct 30, 2024 8:48 AM UTC
  • 142 views
lifalin2016
Forum|alt.badge.img+42
I would assume (dangerous in this case), that a Terminator would halt processing completely.
I have a workspace, that imports from a WFS. It errs because the provider made a breaking change by removing a column in the read dataset. This issues a rejected feature, which triggers a Terminator.
But even then, the postprocess action of my SQL writer is triggered.
Why does this happen ?
If a terminator is called, it indicates that the workspace has failed. And then triggering postprocessing is a dangerous action, as this usually requires the writing to have been completed without errors.
Is this not a bug ?
Using FME 2022.2.6 on FME Server/Flow.
Cheers
nielsgerrits
Forum|alt.badge.img+67
I think this depends on how the transformers are connected? Is the SQL writer only connected with the readers output? Sorry if this sounds dumb but just double checking.
hkingsbury
Forum|alt.badge.img+73
  • Oct 30, 2024 7:57 PM UTC
Yea, you’d want to hold off running any post processing until you’re sure that all API calls have successfully run.
Something like the following would achieve that:
lifalin2016
  • Nov 1, 2024 8:35 AM UTC
It’s not a question of transformers and connections.
It’s the advanced setting “SQL To Run After Write” on the MSSQL_SPATIAL writer.
I have no control on when and if this piece of code is executed. Which is the reason for my question.
I recently introduced a Terminator transformer to force the workspace to fail, and was suprised to see, that the post-process code was executed regardless.
nielsgerrits
Clear. I’m not sure if this is expected behaviour but I would think not.
