Batch deploy mode on FME Server
  • June 12, 2019
  • 6 views
Is it possible to run batch deploy mode on FME Server?
Forum|alt.badge.img+49
Not as such, but FME Server is of course perfectly capable of doing the same thing through automations (FME 2019) or notifications (prior to FME 2019). If you can elaborate a bit on what you want to do I'm sure we can come up with some suggestions.
