ArcGIS Portal Feature Writer - With Editor Tracking Disabled - Still overwrites
  • Oct 20, 2021 3:40 AM UTC
  • 131 views
tiztrain
Hey all,
I am using the ArcGIS Portal Feature Writer and when I push my edits to a feature service, it overwrites the editor tacking fields (eg. createdby, createddate, modifiedby, lastmodifieddate) with my username and today's date and time of upload, instead of values I have prepopulated.
The table sits in a postgres database and I have turned editor tracking off against that table.
Is it possible to push data using the FME writer without those values getting automatically populated?
runneals
Forum|alt.badge.img+32
  • Oct 27, 2021 10:12 PM UTC
This is done on the ArcGIS Online side and it will require you to download the data, update the fields, reupload it, and enable editor tracking again. Take a look at this article from esri that talks about how to make edits to edit tracking fields: https://support.esri.com/en/technical-article/000025504
