Schedules more query to fme_node_health and fme_lock table
  • May 7, 2024 6:36 PM UTC
  • 5 replies
  • 140 views
nicol.ricci
Hi all
I have FME Flow installed in production environment with 2 nodes (Fault-Tolerant installation).
I have now 4 workspaces that i have scheduled every 4 minutes.
My DB Administrator see many query like this
UPDATE fme_node_health SET modifieddate = :1 , expirydate = :2 , timeout = :3 , expiry = :4  WHERE process = :5  AND name = :6
UPDATE fme_lock SET val = :1 , uuid = :2 , expiry = :3  WHERE lock_key = :4  AND (uuid = :5  OR expiry < :6 )
They occours more time and and fill the disk space dedicated to Oracle logs.
It's the first time it's happened to me and I don't understand if it depends on the scheduling or the Fault-Tolerant type installation.
Can someone help me?
Thanks a lot
hkingsbury
Forum|alt.badge.img+73
  • May 8, 2024 9:49 PM UTC
What frequency are you seeing these updates? Looking at a sever I have access to I can see it updating various rows every ~15s.
Seems appropriate as these table appear to be keeping track of the various components of the Fault Tolerant setup
nicol.ricci
  • May 9, 2024 9:01 AM UTC
Thank you very much for the reply.
In fact the frequency is similar to yours.
The problem of the Oracle logs then disappeared: in reality we were releasing many components into production and when checking some things the DB admin raised this question to me because he saw a lot of writings by FME.
Another question: is it possible to configure this write parameter to the DB that you know of?
Thanks
hkingsbury
  • May 9, 2024 8:06 PM UTC
Having a cursory look through the config files, I can’t find anything that seems to control that frequency.
I really don’t think it should change, if anything I’m surprised it only appears to checking fault tolerance every ~15s, I’d have expected it to be more frequent than that.
@rylanatsafe or @siennaatsafe might have some input or be able to get someone else from Safe to chime in
siennaatsafe
Forum|alt.badge.img+12
Hi @nicol.ricci and @hkingsbury,
Thanks for tagging us Hamish.
@nicol.ricci I spoke to our support team about this and it would be helpful if you could create a case. You can create a case for us here: https://support.safe.com/hc/en-us/p/Support
There’s likely some improvements we can make in our internal health check process to not log to the database, or to do it less frequently.
nicol.ricci
  • May 11, 2024 10:42 AM UTC
Hi
I will talk about this with my team and probably i will open a case.
Thank you all
