Get the FME Form Release Info In Workspace
  • Jan 8, 2024 3:33 AM UTC
  • 65 views
bo
Forum|alt.badge.img+10
Hello there,
I looked into FME system parameters and Python APIs to find a programmable way to identify release info, such as 2023.2.1, etc., in an FME Form session, to no avail. I would appreciate you sharing your approaches.
Bo
Best answer by joepk
You can also find these in the User Parameter dropdown menu: image
joepk
Forum|alt.badge.img+22
  • Jan 8, 2024 8:58 AM UTC
Could this be what you are looking for?
joepk
  • Jan 8, 2024 9:00 AM UTC
  • Jan 8, 2024 11:39 AM UTC
+1 for this. Alternatively, you can also query the FMESession object, although the result should be the same as using the constants:
import fmeobjects
fme_build = fmeobjects.FMESession().fmeBuildNumber()  # e.g. 23764
fme_version = fmeobjects.FMESession().fmeVersion()  # e.g. 'FME 2023.2.0.0'
bo
  • Jan 8, 2024 1:29 PM UTC
Thanks, @joepk​  and @david_r​ !
