FME 64 BIT LIMITED TO 4.295GB?
  • August 28, 2013
  • 3 views
Hello,
FME return me this message :
Error - Cannot write out a file larger than 4.295GB. Split your data into two or more shape files
My configuration :
Microsoft Windows Server 2003 family Standard Edition 64-bit Service Pack 2 (Build 3790)
Version : FME(R) 2013 SP2 (20130605 - Build 13499 - WIN64)
if you have an idea to solve this problem because my project size is more than 25 Gb
jy
Best answer by fmelizard
The limitation is the shape file format, as suggested you can split your data to more shape files (project zones?? or create a tile based on the bounding box area of the project for clipping) or write to a different format that does support a bigger file size ( gdb for example)
fmelizard
Forum|alt.badge.img+17
  • August 28, 2013
