Error code 2330 when installing FME 2017.1
I'm encountering problems installing FME 2017.1 64bit desktop (version 02 may 2017).
Installation runs almost to the end, but fails with error code 2330 and rollbacks itself.
I tried downloading it again, same error occurs.
Hope someone can help! Thanks.
  • May 3, 2017
Verify that you're running a 64-bit OS. Also try installing with local administrator privileges.
Maybe also try rebooting your pc before retrying.
erik_jan
Forum|alt.badge.img+17
  • May 3, 2017
Flip, This is something to call Support@Safe.com or get on the live chat on the Knowledge Board page.
I know the last option could have timezone challenges for you.
Erik Jan
