Copy files from one server to another.
poonam21
Forum|alt.badge.img+7
Hello Forum,
I am currently working on a task that involves copying files from a source server (Server 1) to a destination server (Server 2). I am new to FME and am unsure how to approach this.
Could this process be achieved using an FME transformer, or would it require writing a Python script? I would greatly appreciate any guidance or suggestions on where to begin.
Thank you in advance for your support!
nielsgerrits
Forum|alt.badge.img+52
One way to do this is to use the FileCopyWriter.
A different approach would be to use a SystemCaller with dos commands like
copy C:\temp\a\test.txt C:\temp\b\
poonam21
  • January 17, 2025
Hey ​@nielsgerrits
Thanks for the reply.
Using FileCopyWriter, would that be possible for different servers?
nielsgerrits
UNC paths are supported, so as long FME can reach these locations via UNC paths, yes.
