After Upgrade to 2024.2 Our 2 Engines are working, but seem to be unassigned to the server.
  • November 26, 2024
  • 122 views
m.vlamings
After I finished the installation to 2024.2 (upgrading from 2023.1) I seemed to have the same issue as described in this post:
https://community.safe.com/architecture-14/change-engine-name-from-ocalhost-engine1-to-engine1-8676
So I followed all the suggestions in the Best answer by laurawatsafe.
(I blured out url's and server names in my screenshots for privacy reasons)
As described by laurawatsafe I ended up with both localhost and Serverhostname. In the screenshot below you can clearly see that at the moment after I stopped the Engines and was able to remove localhost, there were 0 standard engines assigned to localhost.
So at this point I thought my problem was fixed. (I am wondering why this issue is in 2024.2 as it was fixed in 2018/2019. So this bug seems to have reappeared.)
But now I have some very strange behavior in the interface:
I tried to assign the two engines to my server, but after the delete action of localhost is shows 2/2 engines in use:
This gives error:
I end up with this:
When I sort on hostname on the Engines tab, there still seems to be a refference to localhost:
The strange thing is, that the jobs are running correctly on the correct engines, in the job logging I see the correct enginename displayed:
So does anyone know why this bug resurfaced in 2024.2 and what do I need to do to get 2/2 running engines on my serverhostname?
I did try to restart and rebooted the entire server after my changes to make sure nothing was cached or anything.
Best answer by steveatsafe
@m.vlamings
Perhaps some information on the environment.  Is it an express installation? (it appears to be)
How was the FME Flow Software installed? Did they run it with a command line and passing arguments? Or was this via the Installer?  I have seen this sort of behaviour but only when a silent install was used and COREHOSTNAME or NODENAME was not supplied.
Express Installs using the Installer wizard will lay down the engines with ‘localhost’ as the hostname.  So that’s got me thinking this might have been a silent installer or as you shared, someone tweaked the processMonitorConfigEngines.txt.
Could you stop the engine service (just the FME Flow Engines).  Visit the Web UI and remove the host - it will likely through a REST API error after a few seconds on that page. This typically removes the metadata about the engines. Now try starting the FME Flow Engine service.  What do you see in the WebUI now? Has it corrected itself?  Can you change the engine count? If so you are done.
If not, then likely we need to consider reloading the Engine Templates.  This feels like a new support ticket if you get here.
If someone has manually tweaked processMonitorConfigEngines.txt, then it will be evident if you look at the modified dates in the C:\Program Files\FMEFlow\Server\ location and comparing to the other config files.
Regardless if the file has been changed please review the config file C:\Program Files\FMEFlow\Server\processMonitorConfigEngines.txt
What do you see? Can you share what I am sharing below from that file?
As an example:
TEMPLATE_START_ENGINE="C:/Program Files/FMEFlow/Server/fme/FMEEngine.exe" REGISTER_FME_ENGINE localhost 7070 DEFAULT "C:/Program Files/FMEFlow/Server/fmeEngineConfig.txt" -ENGINE_HOST_NAME localhost
In the example above the engine hostname will appear as localhost (and this example is from an Express Install).
If this file has been tweaked, it will only load back into the system if you set NODE_OVERWRITE=true.
Again, if you get here, probably file a support ticket with us.
steveatsafe
Forum|alt.badge.img+12
  • November 28, 2024
@m.vlamings
As an example:
m.vlamings
  • November 29, 2024
Hello Steve,
Thank you for your reply. It is an Express install that was started using the windows Installer. So no silent install via commandline or other arguments.
At the moment during daytime our development team is using the server, so I will have to stop the engines after office hours and see what happens if I delete the host and restart. I could try that tonight, but I think the problem is in the processMonitorConfigEngines.txt file, now that I looked at it.
As for the processMonitorConfigEngines.txt file. We installed on the E:\ drive so in our environment it is actually in E:\Program Files\FMEFlow\Server\
As adviced in the support article I mentioned before I made a change myself to this file at the bottom of the file, it said:
# Start FME Engine 1
START_ENGINE_localhost_Engine1=!TEMPLATE_START_ENGINE! -ENGINE_TYPE STANDARD
and I changed this to:
START_ENGINE_myhostname_Engine1=!TEMPLATE_START_ENGINE! -ENGINE_TYPE STANDARD
(Where I typed myhostname is my actual hostname, but for privacy I changed it here)
I had overlooked the template settings in this file, I think the cause is there, because it says:
# ENGINE process configuration template
TEMPLATE_START_ENGINE="E:/Program Files/FMEFlow/Server/fme/FMEEngine.exe" REGISTER_FME_ENGINE localhost 7070 DEFAULT "E:/Program Files/FMEFlow/Server/fmeEngineConfig.txt" -ENGINE_HOST_NAME localhost
So I guess if I change it to:
TEMPLATE_START_ENGINE="E:/Program Files/FMEFlow/Server/fme/FMEEngine.exe" REGISTER_FME_ENGINE myhostname 7070 DEFAULT "E:/Program Files/FMEFlow/Server/fmeEngineConfig.txt" -ENGINE_HOST_NAME myhostname
and set NODE_OVERWRITE=true
this would most likely fix it I guess?
Do I need to change anything to this:
because I have 2 engines, can I also add:
START_ENGINE_myhostname_Engine2=!TEMPLATE_START_ENGINE! -ENGINE_TYPE STANDARD
Or is this not adviced? Please let me know if my assumptions are correct, then I will try this tonight after working hours. First to only modify the processMonitorConfigEngines.txt file, my guess would be I only have to restart the engines after that and the server does not need to be deleted in the WebUI. I will only do that if I cannot assign the engines to the server.
Thanks,
Martijn
m.vlamings
  • November 29, 2024
Hi Steve,
I changed:
I also added:
# Start FME Engine 1 & 2
I used restartFMEFlowWindowsService.bat to restart everything, and when I logged in to the WebUI as admin, everything looked great and works. And both engines are already assigned correctly to the server and running.
Now that everything is working I commented out #NODE_OVERWRITE=true So that it does not get unnecessary overwritten in the database with every restart.
thanks a lot, I'm new to FME but now I feel confident enough to upgrade our production environment :-)
