XQuery: replace element value with counter
gpt_geoinfo
Hi all,
I'm getting stucked.
Following problem is to be solved (hope the schematic sample will describe it):
inpu xml:
<greatgrandfather> <grandfather> <father> <child>foo</child> </father> <father> <child>boo</child> </father> </grandfather>
<grandfather> <father> <child>doo</child> </father> </grandfather> </greatgrandfather>
expected output xml:
<greatgrandfather> <grandfather> <father> <child>0</child> </father> <father> <child>1</child> </father> </grandfather> <grandfather> <father> <child>2</child> </father> </grandfather> </greatgrandfather>
goal
My goal is to replace the child's value with their index appearance within this xml, kind of counter.
What I already did:
I took the transformer XMLUpdater with
UpdateType = Replace contents
XML Path = greatgrandfather/grandfather/father/child XQuery = let $count := 0 for $elem in //child let $count := $count +1 return $count
This gives me back
<greatgrandfather> <grandfather> <father> <child>1 1 1</child> </father> <father> <child>1 1 1</child> </father> </grandfather> <grandfather> <father> <child>1 1 1</child> </father> </grandfather> </greatgrandfather>
I don't see the wood for the trees. Can anybody help me?
Thanks in advance!
gio
Forum|alt.badge.img+15
  • May 12, 2014
hi,
I think you should count the father where child>0 ; elem in father
also i think it will never be 0. There appeaar to be no childless father in your example... ;)
gpt_geoinfo
  • May 16, 2014
Thanks for the quick answer.
Well, I found a better solution:
XQueryUpdater:
for $elem at $d in //SymbolInstance
return replace value of node $elem with $d
