XML Templater is slow while writing huge xml file
  • Jan 14, 2021 12:22 PM UTC
  • 7 replies
  • 94 views
I have an requirement where to write an xml file with around 12MB, which is taking almost 30 mins in a 16GB ram server. Is there any alternatives
chrisatsafe
Hi @bhargavait​ ,
Just to confirm are you only seeing this behaviour on FME Server or on Desktop as well? Can you also let us know what build of FME you are using or upload the log file so we can have a look?
If you'd prefer, we can create a support case for this so one of our experts can look into this with you?
  • Jan 16, 2021 11:36 AM UTC
Hi @chrisatsafe​
Same behavior either in desktop or in server. I am attaching log for desktop which has 16GB RAM and FME2016. I have extracted part of the log and has uploaded. Let me know if this is sufficient to help?
What I try to do in the workspace:
I use multiple sql executors to extract data from table and fed to xml templater, once the data is received the tempalter will start processing and takes huge time to write the next log line. example, all features received at 03:02:08, but the next log line is at 04:41:29
And the time varies depedning on the no of features being fed to xmltemplater.
chrisatsafe
Hi @chrisatsafe​
I looked through our system and it appears there were some slowdowns in past versions of the XMLTemplater. By any chance would you be able to try this in a more recent version of FME? It doesn't have to be 2020, 2018 or newer should work as there was a fix implemented starting 2018 (build 18096+).
I understand you won't be able to test this on server but it's worth trying it on desktop to see if you still experience the same issues. Please be sure to right click on the XMLTemplater and choose Upgrade Transformer if it is available. Also note, you can have multiple builds of FME installed on your machine for testing so there is no need to uninstall 2016.1.
  • Jan 18, 2021 7:46 PM UTC
Hi Chris,
I can clearly see an improvement but still its a lot(40 minutes for execution of XMLTemplater), I used FME 2018 Build 18295 in a standalone pc. Please find attached log for more information.
Is there any improvement that can still be done? or any chance of improvement in latest version. The same case for JSONTemplater as well, The higher the features in child/parent templates, the slower it is to generate the output.
  • Jan 18, 2021 7:48 PM UTC
Small addition to my statement, the above result is from 8GB machine(FME2018) as that of 16GB RAM(FME2016) in the past.
chrisatsafe
Possible that there has been some improvement in more recent builds as well. Want to try in the latest beta or official release? If it's still slow, we'll open a support case and file an issue to see if our team can address the problem.
  • Jan 18, 2021 9:38 PM UTC
Hi Chris,
yes, I shall download the latest version once and will keep you posted
