XML (Real-estate cadastre information) to IFC
  • Oct 31, 2024 10:44 AM UTC
  • 198 views
n.d
Forum|alt.badge.img+7
Hello everyone,
I have an XML file containing the registered real-estate data and want to export it as an IFC file.
What is the procedure to get the geometries and their atributes out of that file.
As I have read, the first step is to use the XMLFlattener. But I do not know on which level do I have to flatten it (Elements to match). There are a lot of nested paths. If I select one path, do I have to select the paths under it?
And this flattening process takes a really long time!
What is the solution?
I would appreciate your help.
Best answer by kailinatsafe
Hello @n.d, thanks for posting! Are you using the XML or GML Reader? If the XML contains geometry or it is a GML file, there may be a chance the GML Reader could automatically recognize the geometry on read. Otherwise, are you able to share a sample XML file containing a couple sample features for testing?
Not too familiar with IFC Writing, but this article demonstrates how to write custom property sets. I recommend downloading the article workspace and stepping through the tutorial before applying concepts to your own data! Happy to help, Kailin.
kailinatsafe
Forum|alt.badge.img+24
  • Nov 4, 2024 6:21 PM UTC
n.d
  • Nov 6, 2024 1:22 PM UTC
Hi @kailinatsafe,
Thanks for your help.
I imported it as a GML file. I skipped the flattening process. That was a good trick.
The other problem was with the Geometry. It couldn’t be written to the IFC. But after trying several Geometry tranformers, I could have my geometries written in the IFC file.
