When writing to Autodesk ReCap the RCS output file name is lowercase - how do we force it to be all UPPERCASE?
  • September 23, 2020
  • 10 views
danilo_fme
Forum|alt.badge.img+42
Hi @dustinw​
Did you try to usethe transformer BulkAttributeRenamer?
Capturar
Thanks in Advance,
Danilo
danilo_fme
  • October 7, 2020
danilo_fme wrote:
Hi @dustinw​
Capturar
Thanks in Advance,
Danilo
I believe the use this transform is essencial in your case.
