Hi All,
I seem to not be able to get the Tester to work using the in operator when trying to use Sting values.
I am trying to turn the ArcGIS definition query expression Workpack IN ("WDS - SP1", "WDS - SP2", "WDS - SP3") into the right syntax to place into the Tester.
Having the () on either side gave me nothing, I had some luck with the right value being "WDS - SP1", "WDS - SP2", "WDS - SP3", however this only returned values for WDS - SP1.
Cheers
Matt
