I'm trying to count the vertices on line segments. The data is a .GDB and has complex line segments that contain fillets and arcs. The VertexCounter is calculating an incorrect number of vertices for line segments that contain arcs. Is there a work-around for these more complex line segments?
- Home
- Forums
- FME Form
- Transformers
- VertexCounter transformer giving incorrect vertex count on line segments containing arcs.
- April 23, 2019
- 30 replies
- 49 views
- 8320 replies
- April 24, 2019
I agree about sample data being useful. Also, how many vertices should, in your opinion, FME return when encountering an arc?
Notice also that there are 3 different types of arcs in FME:
http://docs.safe.com/fme/2019.0/html/FME_Desktop_Documentation/FME_Workbench/!FME_Geometry/Arcs.htm
- Celebrity
- 3618 replies
- April 24, 2019
4 actually (by centerpoint, by centerpoint with ends, by 3 points and by bulge). According to the VertexCounter they all have 1 vertex though.
I am not sure what I would prefer to see to be honest, depending on how it's defined an arc in a complex line doesn't actually add a vertex imho.
- 8320 replies
- April 24, 2019
Wouldn't an "arc with centerpoint (no ends)" be considered a circle or an ellipse?
- Celebrity
- 3618 replies
- April 24, 2019
Only if it has a sweep angle of 360 degrees I would say. But we're getting into deep geo-existential subjects here ;)
- 8320 replies
- April 24, 2019
Yes, it's getting nerdy in here, but I like it ;-)
From the docs "The arc's definition implies start and end locations, but sometimes these locations may also be set explicitly." So my take is that the ArcByCenterPoint always has both end points, either implicitely or explicitely, so for the VertexCounter at least there should be no difference.
Also in the docs: "There are 3 ways to represent an Arc in FME." ;-)
- Author
- 24 replies
- April 24, 2019
Would you be able to provide sample data?
I'm unable to provide sample data but I can provide a screenshot of a typical line segment in my dataset. If you notice in the attribute table, the highlighted record has a column for VxCount_Pre, PREcoord_count, and POSTcoord_count. VxCount_Pre is the vertex count that I calculated in ArcMap using the Field Calculator. The PRE and POST coord_count are from the VertexCounter Transformer. As you see, the numbers don't match.
The line segment is highlighted in green and has it's corner rounded using the fillet tool in ArcMap. Rather than this be just one line segment, it seems like FME is considering this a line segment and an arc.
- Author
- 24 replies
- April 24, 2019
I would like VertexCounter to return the actual number of vertices that each line contains.
- 8320 replies
- April 25, 2019
So if I understand this correctly, the following line with 3 segments should return 4 vertices?
Green are straight segments, red is an arc segment (regardless of type).
- Celebrity
- 3618 replies
- April 25, 2019
I wonder if there's been some stroking done to it somewhere along the line. Could you do this for us?
- Load the data in Data Inspector again.
- In the Display Control panel, right-click on the layer and make sure the option Mark Coordinates is set
- Zoom in a bit closer to that feature and take another screenshot.
- Influencer
- 3256 replies
- April 25, 2019
Easy enough to recreate, the vertex counter does appear to stroke the arc in order to count the coordinates. Not sure what I'd expect to be the correct output in this situation, but I don't think it's correct to describe a line made up of two lines and an arc as having only 4 vertices either though
- 8320 replies
- April 25, 2019
Interesting to see that the VertexCounter is stroking the arcs internally. In my opinion this would be a very useful thing to note in the transformer documentation, @mark2atsafe
- Author
- 24 replies
- April 25, 2019
So here is the line zoomed in with 'Mark Coordinates' checked in the Display Control panel. This line in GIS only has 4 vertices. It is a single line. How is the VertexCounter getting 21 vertices?
- Author
- 24 replies
- April 25, 2019
David, it is one line segment with 4 vertices.
- 8320 replies
- April 25, 2019
I suspect @egomm is right, the VertexCreator seems to stroke the arcs internally before counting the vertices.
You should consider contacting Safe support to confirm. Point them to this thread for details.
- Contributor
- 3725 replies
- April 26, 2019
@cshir065 Arcs of all types within an IFMEPath get stroked by the VertexCounter and return a high vertex count. But arcs not within IFMEPaths, will get a _coordcount of 1. Also, the node between two adjoining lines within an IFMEPath is not counted twice by the VertexCreator. Would it make sense that arcs within IFMEPath be counted as 1 vertex?
- Safer
- 2503 replies
- April 26, 2019
Thought I'd paste a quick answer to address some of the comments and see if we can come up with a workaround...
I think that really ought to be changed to not stroke an arc. I don't see why it should be stroked at all. I'll liaise with Dan and the developers to see if we can get that changed, or if there's a reason it really ought to be stroked.
Do note that the Stroking Tolerance parameter (under Workspace Parameters in the Navigator) will affect the result. So if that's set to a particularly high number, then it would return 4 points for an arc.
One workaround would be to use the PathSplitter to separate out the arc. I think this must be a path. I don't see how you can get a line with embedded arc any other way. So PathSplitter, count the vertices (and maybe subtract the number of features to ensure where two lines meet isn't counted twice). Or just PathSplitter and filter arcs to handle them differently (count them however you want).
The other thought I had was a Chopper - but that strokes the arc too. Still you could probably filter out the mid-section vertices (use a DuplicateFilter on x/y, count the remaining features, add two to the count for the start/end points).
- Author
- 24 replies
- April 26, 2019
Thanks, @mark2atsafe I'll try this work-around.
- Author
- 24 replies
- April 26, 2019
@danatsafe I'm not sure if arcs within the IFMEPath be counted as 1 vertex makes sense to me.
- Influencer
- 3256 replies
- April 26, 2019
Is there a way to identify if a feature is a path without splitting it?
- Influencer
- 3256 replies
- April 26, 2019
A thing to consider, if breaking a path down into constituent parts, if the arcs are at the beginning or end of the feature, counting coordinates and then subtracting the number of features the end result is going to be one less than what is probably desired.
- 4 replies
- April 26, 2019
Very informative, indeed. Thanks! Will take note of these.
- 8320 replies
- April 29, 2019
If, by path you mean a path containing at least one arc, see:
https://knowledge.safe.com/questions/90393/how-to-filter-polygon-which-are-composed-of-both-l.html
- Influencer
- 3256 replies
- April 29, 2019
No, a path with or without arcs.
- 8320 replies
- April 29, 2019
I think a PythonCaller with this check should work:
geom = feature.getGeometry()
if isinstance(geom, fmeobjects.FMEPath):
# feature geometry is an FMEPath instance
Related Topics
Filter grid records by custom fieldicon
Develop CustomizationsEnable Filtering and Sorting for Unbound Custom Fields in Grid (AR402000)icon
Develop CustomizationsHow to add selection criterias to a view that has a delegateicon
Other Developer TopicsGet Selected checkbox in grid to post back on Process Shipments screen when selected/unselectedicon
Low Code | No Code Customizations or IntegrationsGetting PXData.PXLockViolationException when deleting records from table on every other attempticon
Helpful Members This Week
- virtualcitymatt
30 votes
- ebygomm
29 votes
- nielsgerrits
21 votes
- hkingsbury
20 votes
- redgeographics
20 votes
- crutledge
16 votes
- geomancer
15 votes
- takashi
15 votes
- liamfez
10 votes
- david_r
9 votes
Recently Solved Questions
Unable to connect to IBM DB2
1 ReplyAdd creation date of file A as data in a new column of file B
1 ReplyIs there a way to extract coordinate system from datasets to be standard ESRI coordinate system names?
5 RepliesCalculating population from point located in a buffer/surface
1 ReplyGeometry Validator not repairing Self Intersection
Community Stats
- 31,056
- Posts
- 117,723
- Replies
- 38,830
- Members
Latest FME
Scanning file for viruses.
Sorry, we're still checking this file's contents to make sure it's safe to download. Please try again in a few minutes.
OKThis file cannot be downloaded
Sorry, our virus scanner detected that this file isn't safe to download.
OKCookie policy
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
