Translation from OpenStreetMap OSM to Shapefiles: Building line from Nodes failed
  • September 18, 2014
  • 0 replies
  • 6 views
I am trying to translate from an OpenStreetMap OSM to shapefiles. The log is displaying "Building line from nodes failed: Node id 'x' is not an integer."
I was just curious about what is causing this and what I could do to fix the issue?
Be the first to reply!
